02-01-2018 04:41 PM - edited 01-04-2022 03:26 PM
02-01-2018 08:07 PM
Public Mobile won't be able to provide that information for you. To get that info, you must manually go into your phones Settings, then go to your data settings. There should be a graph showing which apps use the most data.
02-01-2018 05:39 PM
@srlawrenwrote:
wrote:When I go to self serve there are 70+ pages of comments - where do I find MY history ONLY?
@Lorraine1 no no, not the self-serve section of the community--your self-serve account. Use the "My Account" link at the top of any page.
Nice catch ![]()
02-01-2018 05:37 PM
@Lorraine1 also, how to check what apps are using your data: on an iPhone, or on an Android phone.
02-01-2018 05:36 PM
02-01-2018 04:57 PM
@Lorraine1wrote:When I go to self serve there are 70+ pages of comments - where do I find MY history ONLY?
Unfortunately, you will have to go through manually. But since you are looking from the past week or so, you won't need to go through all pages. Data usage is labeled as Web.
02-01-2018 04:53 PM
02-01-2018 04:51 PM - edited 02-01-2018 04:52 PM
Also a good idea to check your phone to see what apps are using data and how much of it. Also make sure features like wifi assist or similar are turned off as those will eat thru data quickly.
I had an issue of an app eating thru 400mb in a couple days last month because I didn’t deactivate cellular data for it and my wifi must have been spotty so it would use data instead. Lesson learned.
02-01-2018 04:43 PM
To check your usage, go to Usage History from your self-serve account. You will have to go through some pages to see when you used your data.
What plan are you on and did you recently go through renewal?
