Data Stopped Working
11-15-2016 11:54 AM - edited 01-04-2022 06:21 PM
Hi,
My data just stopped working 2 days ago. Calls/Texting works fine, but I am getting not data.
I have PMed all the mods but have not received a response.
Can anyone help?
Edit: My data had been working fine up until 2 days ago. I have been using Public Mobile for about 4-5 months now.
Thanks
Service
11-15-2016 12:25 PM
I see.
This is poor and unacceptable customer service. Especially with something so important to people that affects their daily jobs/business.
11-15-2016 12:22 PM
@admlw it's because of all of the new customers with the promotion that's going on. You might have to wait a bit to hear back because they are dealing with people with porting issues.
11-15-2016 12:03 PM
That is another problem I am having. Accidentally locked myself out and also forgot my security question answer so I cannot reset my password. lol
I am hoping one of the mod's can help. Usually they're very fast to reply. But I have not heard from anyone yet.
11-15-2016 12:03 PM
Have you tried turning off your phone on and off again?
Also, try and double check if your APN settings are up to date.
Take a look at this thread.
http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartph...
11-15-2016 12:02 PM
Samsung s6
11-15-2016 12:00 PM
When you log into self serve, does it have your data usage there? Is there any possibility that you could have accidentally used up the data?
11-15-2016 11:59 AM
What phone are you using?
