02-21-2020 06:50 AM - edited 01-05-2022 09:36 AM
Can anyone comment as to what ave data speeds you're getting with PM. Im new to PM and I noticed that when I change my preferred network type settings from 2g/3g/4g (automatic) to 2g/3g I get better speeds. So I went from 3mbps to 7mbps roughly. This is a new phone (One Plus 7) so Im wondering if its my phone thats slow. Im in Ottawa area.
Joining Public
02-22-2020 02:19 AM
@Bullet77 wrote:I have foud that if I leave my iPhone set for LTE enabled in settings my speedtest speeds are slower than if its disabled. I get close to 3 mb/sec down in 3G setting and 1.7/sec ish if LTE is enabled
That was explained earlier. On currently offered 3g plans, only the LTE network has throttled speeds.
02-21-2020 10:40 AM - edited 02-22-2020 11:57 AM
I have found that if I leave my iPhone set for LTE enabled in settings my speedtest speeds are slower than if its disabled. I get close to 3 mb/sec down in 3G setting and 1.7/sec ish if LTE is enabled.
02-21-2020 07:07 AM
@gjong26 pm throttled it's LTE speed at 3mps (3g speed). Switching to the 4g network you will have unthrittkrd speed but higher latency.
For most people the throttled LTE is fast enough. If you want full LTE speed you need to go to Koodo Telus or other providers.
02-21-2020 07:05 AM
All new plans are currently LTE throttled to 3mbs speed. It's not real LTE as it's throttled to 3G speeds.
Some older plans that people may be still on are full LTE.
If you just signed up your account will tend to give different speeds for first few days until account is provisened properly to throttle your speed to 3MBS. So not really worth doing speed tests..
