05-06-2026 07:02 PM
Over the last hour I've been receiving "No mobile data service - temporarily turned off by your carrier" notifications. Is the an ongoing service outage?
a month ago
if struggle with chatbot, use the direct message link:
a month ago - last edited a month ago
Sorry. The order of the board display made me think this was a repeat answer. If you got a notice of my original post was out of frustration, I apologize. Too much struggle with the chat bot.
a month ago
There has been some outage in Vancouver for some time, but on and off
telus.com/en/bc/outages
And ask PM to check
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
05-06-2026 08:10 PM
I did all those things before posting. The phone was working fine this morning. I've used less than 10% of my data allowance and the phone has been rebooted several times.
Is there an outage of network in BC?
05-06-2026 07:48 PM
Check your data usage in My Account
And make sure you have Mobile Data enabled on your phone. But make sure Mobile data limit is disabled
And try Reboot phone and Reset Network Settings
