no internet
Yoonix2
I dont have internet. I checked my account I didnt use all my data but I was not able to use it for last 4 days. It was working before.
Hello @ Yoonix2,
I sent you a private message. You can view it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
@Yoonix2
What phone do you have?
Make sure you have disabled the Mobile data limit on the phone
If you have a physical sim, try it on another phone.
If you have an eSIM, get a replacement eSIM for free using the PM app, this will re-provision the account
I have also escalated your ticket on your behalf.  PM support will reach out to your via Community inbox.  Please monitor here for their reply:
Yoonix2
I tried airplane mode and back and rebooted my phone. There is a service outage on telus system since April 1!th in vancouver with degrading service. I cant even pay parking with my phone. This is unacceptable. Thanks
@Yoonix2
Try resetting the Network setting on your phone and reboot your phone.
If that didn’t work then check for outages in your area:
https://www.telus.com/en/bc/outages
