Data Reset
Sylvie1968
My payment went through yesterday, but my data did not reset.
11 REPLIES 11
HI @Sylvie1968   Look good on your device.
Last thing  to check is your Usage history in My Account.  Filter out from July 15 and see how much it said used
Then send all these info and screenshots to PM CS Agent.
To open ticket
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
Can you look at your View Usage History and find those data lines. It's not unheard of around here that data doesn't get reset. But we can still find ways to make sure it is that rare occurrence. (I'm not sure why I had to set the date to the 15th to see items on the 16th ??)
Sylvie1968
My phone data usage says i only used 1.26mb since july 15.
Sylvie1968
I don't leave my data on.
I did not use 975mb in a day and half.
The data usege that is currently showing was my data usage before renewal on july 16. It did not reset the data at renewal.
dust2dust
Were you out of data before your renewal?
Do you always leave your data on?
Will your phone let you see which apps or the OS took all that data in a day and a half?
Hi @Sylvie1968   can you check 2 more things
Check Usage Log, see how much data since July 16, just filter out the data traffic
then check your mobile data usage on your phone if you are using Android.   See if they match
Sylvie1968
 yes, i checked several times yesterday and today.
Also, I keep getting an error 404 message.
Sylvie1968
 data has not reset with the new billing cycle.
Meow
Could you provide screenshot of your account (mask personal data)? It should reset for sure...
hairbag1
Log in to your account / Plan and add-on to see how much data you have currently.
Let us know too.
edit...I just checked and PM web has "crashed" again, so you'll hafta wait until things stabilize before investigating further.
HI @Sylvie1968   did you check My Account?  it should show the usage clearly now.
Do you mind to provide a screenshot?
