Data Not Working
ShareBear143
This is my second month with Public and the first month no problems with my data . Now second month and my days will not work AT ALL . I don’t understand why it worked with no issues then just nothing . Can someone please help me. TIA
7 REPLIES 7
ShareBear143
Phone calls texts are working no problem , Just my Data and it’s an ESIM
and phone calls working, right?
only PM sim there and no other sim/eSIM?
if you have a physical sim, test it with another phone
ShareBear143
How do I find that? Ty
ShareBear143
I have an iPhone 15 pro max
ShareBear143
No my data has not ran out . My second month my data just stopped working and I paid for 100gb with my plan . I have been trying to reach support via chat but that is not working for me as well the page goes blank . I have tried atleast 20 times as this is very frustrating . Thank you for replying back I will reset my phone again to see if it will do something .
slusagm
What phone you have?
Make sure you disable the Mobile Data Limit on the phone
@ShareBear143  Are you sure you haven’t used it all up and or you do t have a data limiter set in your phone for each month as public mobile is every 30 days and not monthly possibly. Can also try and reboot your phone or reset network settings see if that helps so long as account is active and not in suspended state
worst case ask support to investigate
you can use the orange chat bubble bottom right of screen  or send  a  private message   To CS_Agent
@ShareBear143
