Data Limits
diluz
Hi, will I get a message when my data is nearly used up?? Will the data just stop working, or will I start to get charged for going over?? Thanks
2 REPLIES 2
@diluz  Communication here is hit or miss so you may or may not get a text when close to the end of your data . But if you use it all up it will just stop working . pM is pre paid so never any surprise bills . You can only use what you have already paid for
@diluz PM is prepaid provider so data will just stop after all used
yes, you might get a text reminder when data are 90% used
