Data Advice
joesugarman27
Is Paying for 4G LTE Really that much better than 3G.
Advice Please
Thanks! 🙂
2 REPLIES 2
bridonca
I think the only advantage of full LTE speed is with high bandwidth video, and with such low data caps, high bandwidth video is a poor appication for this data, because it eats into your data cap so quickly.  You will be still using LTE data with the 3 speeds, with the same latency advantages as LTE, albiet throttled.  I am told it is throttled at around 3.5 mbit/s, which is more than sufficient for most cases.
NDesai
Other than the full LTE speed, you won't notice any difference in usage.
You will find more info here: 3G vs. 4G LTE - What speed is right for you?
