Data Add-on
lidya
I recently purchased a data add on it says I have 15 dollars balance but no data amount was added that I can use. What can I do to use the amount I bought…?
@lidya Yes it does,at least if you don’t use it all it will still be there if you run out of your regular data Next cycle
lidya
I know and my data tends to run out at the worst of times 😊
@lidya   yes, it is a confusing procedure.   it should be a one step process instead  🙂
happy that  it is sorted out now
lidya
Thanks a lot it worked 😊
iliketotalk
@lidya  hello buying a add on is a 2 step process first you add funds(you did that) now go back and purchase the add on
@lidya   Because you just loaded the fund and not buy the add on yet
Buying addon is a 2 steps process
1. Load fund
2. actual buying
you did step 1 but not step 2 yet.  Go back and buy now.  PM will use the money from Available Fund to complete the transaction.  So, no worry, just go ahead and buy.  Once bought, reboot your phone once for the new addon to activate
