05-08-2020 11:34 AM - edited 01-05-2022 10:42 AM
I added 2 g's of data yesterday and my account only shows 1 G. My transaction history shows a withdrawal of the $40. that I had added to my account. Is this what should happen?
05-08-2020 11:44 AM
@ecowen wrote:This post is a stupid mistake!!! Please ignore it and thank you to all who responded.
I'm glad I'm not the only one who makes mistakes !!
Stay safe.
05-08-2020 11:42 AM
05-08-2020 11:41 AM - edited 05-08-2020 11:42 AM
@ecowen wrote:I added 2 g's of data yesterday and my account only shows 1 G. My transaction history shows a withdrawal of the $40. that I had added to my account. Is this what should happen?
The cost of data add-on right now is $15 / 1 GB. If you bought 2 GB's, you should still see $10 as available. If you only bought 1GB, it'll show $25 still on your account.
05-08-2020 11:41 AM
@ecowendo you mean 2 gb add-on? (each 1 gb is currently $15)
Or did you opt for a new activation of the 2 gb plan at $35?
So $40 was charged on your account. What amount is remaining in your available funds now?
As others posted, add-on purchases is a 2 step process.
05-08-2020 11:40 AM
Thank you
05-08-2020 11:39 AM
@ecowen hello you probably still have to buy the 2nd gig money is probably still in your self serve
05-08-2020 11:36 AM - edited 05-08-2020 11:37 AM
It is a two step process to purchase add-on and add it to your account.
To purchase Add-Ons using your Self-Serve account, follow these steps:
- Click on ‘Purchase Add- Ons’ on the Overview tab and scroll down to the Add-On calculator.
- Click the plus sign (+) to add and the minus sign (-) to remove selected Add-ons.
- When you’ve added all your desired Add-Ons, click ‘Buy Add-Ons’ or ‘Make a Payment’ below the calculator:
- You will see ‘Make a Payment’ instead of ‘Buy Add-Ons’ if there are not enough funds in your account to make the purchase.
- If you don’t have sufficient funds to purchase the Add-Ons, you will be asked to make a one-time payment equal to the price of the Add-On, less your current available funds. Click ‘Submit’, then ‘Go back’: now the button below the calculator will say ‘Buy Add-Ons’.
- Select ‘Confirm my purchase’, and you’re off to the races!
