Data Add on
jtrotman
I added 1GB to my plan for $30 about a week ago. It charged to my credit card, however, I am not seeing any data coming through. Does anyone know what the issue is?
Luddite
Login to your account. If you see Available Funds = $30 just "buy" it again.
Otherwise, is it possible you used the data? Data add-ons disappear once used up. You can check your usage in your account.
If neither is true, click this: message to moderators to send a private message to the moderator team with your phone number and an explanation.
closng
The add-on purchase might not have gone through, this happened to me once. Go back into your account balance on self-serve and check, there should be a credit balance for $30 still sitting there.
Just purchase the add-on again. This time around, you will not have to enter your credit card info, it will just deduct the purchase from your existing credit.
Hope this is the case for you.
NDesai
Do you see the 1GB add-on on the Overview page in your self-serve account? Or Do you see the $30 as Available Balance?
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
