Data Add on not working
public19
I just purchased a data add-on to my plan. However, it has not kicked in yet. Does it apply immediately or do I have to wait for sometime. I bought the add-on online in my Public account. I urgently need data for tomorrow. Any support/assistance is appreciated.
Thanks.
7 REPLIES 7
public19
Thank you for the suggestion. It was the data limit setting in my phone. It works now.
I don't have
@public19 wrote:
 I see the add on 0.99 GB left still in my online account.
@public19   So, the addon is definitely purchased.
Reboot the one once more
and are you Android or iPhone user?
public19
In Canada
public19
My data for the month expired this morning. That's why I purchased the add-on. I read in other posts as well that it should kick in immediately. However, the data isn't working in my phone. I see the add on 0.99 GB left still in my online account.
HI @public19
did you reboot your phone?
Login to My account and see if the add-on you purchased is there
And, you have any data limit set on your phone ?  Android has that and it will stop any data consumption once the limit is hit.  If you have that, please disable it
Timer
@public19
you purchased a data add-on in canada or USA.
Data add-ons should work immeditely after purchase. Was data working before?
