Current plan
07-26-2023
10:39 PM
07-27-2023
05:30 AM
computergeek541
07-27-2023 03:28 AM
It depends on what is actually available in your current physical location, if all you get is 3g then consider switching to a 3g plan
07-26-2023 11:12 PM
if you have the current $15 or $25 plan with 3 G speed...you're exactly what you paid for. You should see that you're on a 4G, 5G or LTE network but your PM account is choked to 3G speed.
07-26-2023 10:47 PM - edited 07-26-2023 10:48 PM
@Lana3 check your Preferred network type or network mode. Usually it is good to leave it with Automatic, but try changing to 4G and 5G and see if your phone connects (Yes, while you have a 4G plan, you are free to access the 5G network as well, just that the speed will be capped to 4G speed according to your plan)
Let us know if that works
