01-25-2025
05:48 PM
01-26-2025
05:28 AM
computergeek541
01-25-2025 05:57 PM
HI @Janie2
is that a problem with transferring into PM? Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
01-25-2025 05:55 PM
@Janie2 Are you transferring into or out of Public Mobile?
01-25-2025 05:50 PM
PM won't contact you. Here, everything is by ticket and message
but you are lucky if you are porting in your number, there is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
