Credit card
gbranscombe
I've tried 3 different credit cards and I cant activate my sim . Ive started the process 5 times with no success. Is the system down ? Any ideas? Thanks
15 REPLIES 15
Good tips @KarenVey
but sometimes, it is not Edge or Chrome, it just you need to keep changing browser,  keep clearing cache or keep using Incognito mode
KarenVey
i had huge problems with ms edge, switched to firefox and the payment went through instantly, just a thought
@gbranscombe wrote:
Already have. Thanks
@gbranscombe
As I have already noticied this being done a couple of times, please do not accept your own posts as solutions.
gbranscombe
Will do. Thanks.
gbranscombe
gbranscombe
No success
gbranscombe
No I am not getting past payment info.
Timer
@gbranscombe
clear cache and cookies and use one page inPrivate mode,
or contact to support team by send a private message to  CS_Agent
gbranscombe
It just doesn’t take the payment info in different browsers etc.
@gbranscombe wrote:
Yes I did. Tried it all. It just says there are errors in the info.
HI @gbranscombe   could be the system, there are quiet number of posts about trouble with credit card
Open ticket if you have not done yet
gbranscombe
darlicious
@gbranscombe
Check your credit card. Have you been charged for the plan? More than once? If so and the sim card does not work once rebooting your phone and/or you have been charged more than once on your card contact customer support to reprovision your sim card and/or refund the excess charges on your card.
Edit:
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here   ....for additional member supplied info.
@gbranscombe  - are you passing the payment section within the activation process?
If so, insert the SIM and see if you have any services.
IF you have not past that section, try to click this link to use the: Public Mobile Online Activation Assistance
If your card did get charged and you are wondering if activation took place, contact CSA.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
MrSpock
@gbranscombe  hi did you try using a different browser try secret or ingognito mode
HI @gbranscombe
there seems to lots of credit card issue with the new My Account system.
But you tried many times and maybe  a Fraud lock is triggered.  Please open ticket with PM CS agent and they can check it.
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
