09-27-2022 03:13 PM
Trying to activate and tried all the card I have (5 cards) nothing works.
Please help.
09-27-2022 03:59 PM - edited 09-27-2022 03:59 PM
I can positively confirm that using secret/incognito mode works. I had no issues with using my credit card like I did last night. Good luck and welcome to public mobile!
09-27-2022 03:36 PM - edited 09-27-2022 03:36 PM
Dang it. I had the same problem last night I was hoping waiting it out would help. Best to follow the above advice but most especially use secret / incognito mode this time around. But you will have to wait out 1 hour since you had last finished trying your activation. Maybe I'll give mine a go and tell you if it works now.
09-27-2022 03:15 PM
@otmosziz hi you may have to start over, clear your cache and try a different browser in private or incognto mode, rebbot your device and try again
