Create my own number
Yea123
Hi, is it possible to get a customized mobile number from PM app? Is it even possible?
anyone knows?
7 REPLIES 7
@hTideGnow wrote:
sorry, no carrier allows that.
Most carriers actaully do allow it to a certain extent, but Public Mobile no longer has any such options (they used to).  Telus Mobility not only has an optoin to search for the last 4 digits, but also has an "Assian friendly" option to search for numbers that could be cosnidered to be good luck or offer good fortune.
Yea123
Awesome! Thanks for the input. I will try this.
Chalupa_Batman
Hey @Yea123
This is what I did. I downloaded Fongo, TextNow and a few other VOIP apps. Played with each one until I found a number I liked on each. Narrowed it down to which one I wanted most, then I ported it over here to Public Mobile. I've had the same Fongo "borrowed"... hehehe...  number for almost 10 years now. Hope this idea helps.
OH. And when you think you found a number you really want to port, check here to see if it can be ported.
Check Eligibility to Move (koodomobile.com)
Go get em tiger!!
Yea123
I see, most likely i would have to do that. Thank you so very much for the reply.
Sansan
No, you can't.
But you can look through the lists of numbers and choose one that looks close to what you want. If you currently have an account you can sign on. Go to Profile. There is an option  to choose phone number based on province. It will give you the random numbers, you choose the last 4. Keep refreshing until you see one you like.
Yea123
Thanks for the reply. Good to know.
HI @Yea123
you can buy the number from someone who owns it already, but not from mobile carrier, not for consumers
