07-29-2022 01:30 PM
I would like to create an account. I am already Public M. member. Thanks.
07-30-2022 12:11 AM - edited 07-30-2022 12:11 AM
just tried, clicked the on the Register now button , the choice came up not really about setting up an account, more about forgot password.
problem with chatbot, not all choices are 100% matching the situation.
07-29-2022 01:54 PM
did you activate in store or activate yourself online
If you activate yourself online , you should already have a My Account created , maybe you will then need to reset the password
If you activate in store, then yes, usually the My Account would not be created yet.
You will have to come to this direct link to open ticket with CS agent
https://urlshortner.tiia.ai/XZxMjt
Click "Contact Us"
and then Click "Click here to submit a ticket"
you will then direct to another page to open ticket. Please choose "Self-Server password reset" in that particular form
07-29-2022 01:36 PM
Top right corner of Community page. Hoover over Sign IN, click on My Account and you will get to
Follow prompts, fill out whatever PM is asking to.
07-29-2022 01:35 PM
@reginofrontela Hi you can create an account here https://widget.telus.tiia.ai/chatbot.html?botId=ZJkWuVb7Hp6EEcTIZKMZbvLwuDV&duid=2BXKyAsUGl2N10AVl7w...
