Coverage
GAJ
I will be in the USA for a period of 10 days. Does my current plan cover this ?
edited by computergeek541: changed category label as discussion isn't related to the self serve account/My Account
hairbag1
@GAJ
even if your current plan is Canada only, you can still buy a 15 or 30 Day US talk/text/data Roaming add-on for use whilst in USA. Log in to your Public Mobile account > Shop Add-ons...you'll find a menu of add-ons. Check the US Roaming 15 or 30 day options.
If you happen to have at least 10 Reward Points in your account, have a look at Rewards > Catalogue to see the menu of Roaming add-ons available using Points you can redeem.
Remember ...you MUST have a VoLTE enabled cellphone that is recognized by Public Mobile in order to be able to use talk functions in USA.
slusagm
Yes, if you have a Canada-US or Canada-US-Mexico plan
check it out yourself.  Login My Account, go to Subscription & addons page and it will show you the plan details
@GAJ
Only if you have the Canada/USA or Canada/USA/Mexico plan.
If you have the Canada wide plan then you need to purchase a USA add-on.
With Roaming enabled in your cellular settings. Sometimes you will need to manually connect to AT&T, T-Mobile or Verizon.
Also, since USA decommissioned 3G. Your phone must be VoLTE compatible to make calls. Check to see if your phone is compatible.
https://www.publicmobile.ca/en/get-help/articles/volte
If not compatible, you can use a VoIP app like TextNow or Fongo or WhatsApp (if both parties have it app).
porcupine
What plan do you have is it Canada 🇨🇦, us,Mexico if so don't forget to turn on roaming yes you will be good
