09-12-2015 08:26 PM - edited 01-04-2022 02:01 PM
Hello folks,
Sorry for my ignorance. But, I am coming from Wind and things are different there.
As Wind is only available in 5 cities, as soon as we get out of the city we have to pay roaming charges.
1. If I am on provincial unlimited plan along with Data, do I have to pay roaming if I am using it from another city. Eg. I live in Edmonton and do I have to pay roaming charges if I use my phone in Calgary (both in Alberta). Similarly, what if I travel to Ontario. Can I still use my unlimited minutes and data there?
Thanks,
V
09-15-2015 02:27 PM
@Martin Perhaps the operators were confused and only meant you were missing one of the four humours; black bile perchance?
Whatever, keep on truckin and eventually Mother will catch up.
09-15-2015 01:34 PM
09-15-2015 01:19 PM
09-15-2015 01:16 PM
09-15-2015 01:10 PM
I must say, I am impressed with the community help.My personal questions are resolved much faster than calling and waiting in line to talk to customer support in other phone companies.
People are very helpful here and I hope it continues to be like this.
V
09-12-2015 10:20 PM
If you did not selecte Canada wide talk than simply purchase an add on if you will travel outside of ur province. Text and data can be used everywhere in Canada.
09-12-2015 09:42 PM
09-12-2015 09:38 PM
@vaibhav Data is Canada wide. Calling with Provincial plan check out this thread: How to call to/from other provinces if on province-wide unlimited plan?
Also, do not confuse US calling with roaming, it is strictly for calling from Canada/Provice to the USA and PM only serves 18 countries with its LD plans.
09-12-2015 09:34 PM
It is clear as glass now.
The only thing now left to confirm with you is about data. Is the data nationwide?
Thx,
V
09-12-2015 09:31 PM - edited 09-12-2015 09:32 PM
@vaibhav wrote:
Ok. Now I am more confused. I had an impression that if you are in Ontario with an Edmonton number (I am talking about Telus), Ontario becomes your home province and you can use your unlimited features in Ontario. But, Edmonton numbers become long distance for you. I got this impression because few of my friends have shifted from Toronto and are still using their Toronto numbers.
And I understand from your response that, I can use my data anywhere in Canada on Telus (PM) network, right? Also same with the incoming calls.
Thx,
V
Hi @vaibhav,
Your friends probably have nationwide calling, in this case, it doesn't matter if they kept a 416/647/437 number, it's all "local" to them no matter where they travelled. However, if you call those numbers, they're long distance as those numbers are not Alberta numbers.
As stated in the quote below from Public Mobile's Plans page:
"Includes outgoing calls you make anywhere in Canada to a number with an area code in the same province, and incoming calls you receive while you are in your home province. A long distance talk add-on is required to receive incoming calls while you are outside your home province."
If you were to call your friends who have Toronto numbers even in Edmonton, it's considered long distance for you because Public Mobile's provincial calling scheme is based on the area code you're calling, not where you're located geographically. That's the difference between WIND and Public Mobile's provincial-based calling schemes.
This is based on my interpretation of that quote. I hope this helps clarify this. Let me know if this is still confusing.
Cheers!
09-12-2015 09:16 PM - edited 09-12-2015 09:17 PM
Thx,
V
09-12-2015 08:48 PM - edited 09-12-2015 08:50 PM
@vaibhav wrote:Hello folks,
Thanks,
V
@vaibhav, I've moved from WIND as well. There's a fundamental difference between the province wide call that WIND has and what Public Mobile offers. Unlike the WIND provincial calling scheme, it doesn't go by the geographical area you're in. So right now when you're travelling to Ontario from Edmonton and in a WIND zone, any calls within Ontario would be free to you.
However, with Public Mobile, provincial calling is not defined by your geographical area but bound to the area code your phone number is in. So if you travel to Toronto and call a 416 number, it's considered long distance.
Just like @Chicklets has recommended, best to get the long distance minute addon for $8 (200 minutes) or 400 minutes for $15 for your travels. If you don't use up your minutes, they don't expire until you've drained all 200 minutes.
PS: WIND has much more than 5 cities, while it may look like it but much of their zones are in Ontario. They have Toronto, Barrie, Peterborough, Ottawa, Brantford, Niagara, Windsor, Kitchener-Waterloo and a couple of other small spots in addition to Edmonton, Calgary, and Vancouver.
Hope this clarifies things.
Cheers!
09-12-2015 08:41 PM - edited 09-12-2015 08:46 PM
You can call and receive calls anywhere in your home province, If you travel to Ontario you can only call people in Ontario but you will be unable to receive any calls. I suggest that you purchase a 200 Canada long distance addon which will give you the ability to call anyone in Canada and also receive calls anywhere in Canada, up to 200 minutes for $8. Well worth it Addons never expire until you use them up.
