Could I return SIM card?
irisxiaolu
I got my SIM card at London Drugs. However, the activation has been unsuccessful with multiple tries. Would I be able to return the SIM card? Thank you!
irisxiaolu
That sounds like a lot of work. I think I will just keep the SIM for future. Thank you for your input!
@Lieux wrote:
You can try to sell it with kijiji??? If it's not opened..
irisxiaolu
https://productioncommunity.publicmobile.ca/t5/Getting-Started/activation-failed-for-new-sim/m-p/336...
The online activation is not successful. Have not got to the step of putting in the SIM card in a phone yet...
@hairbag1 wrote:
Nope...once it's paid for...it's yours. Check at LD, but I think they'll tell you the same thing. Is you phone not compatible with PM ? What phone are you using ?
Lieux
hairbag1
