Connecting to Network
tristangre
Bought sim card and activated it however nothing is working. Text messages phone calls or data. Additionally it says no service. Tried changing APN settings and resetting phone nothing works. Tried on another phone and same problem. Any way I can get help or get this resolved?
@tristangre wrote:
Hi Hollister,
I chose a new number.
Most likely SIM is not properly provisioned. Contact agent for assistance.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
@tristangre the sim card you have was not probably provisioned.  But nonworry, it is an easy fix and you just need to open ticket with PM support and they can fix it easily.
please open ticket via Chatbot
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
Hollister
@tristangre wrote:
Hi Hollister,
Try the steps mentioned above.
If none work contact an agent.
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
tristangre
Hi Hollister,
Hollister
@tristangre
Did you port a number over?
Try:
Rebooting
Resetting Network Settings
Reinstalling sim card
Try sim in another unlocked phone
