02-22-2018 03:23 PM - edited 01-04-2022 03:34 PM
Hi,
This is a bit unusual; it says connected to 3G and 4G after setting up the APN, but I still cannot connect. This only affects one of my phones, but not the other. It works on my Samsung S5 Active, but it won't work on my E&L W6 Three Proofings.
This is the phone I'm trying to get it working on, specs in the link.
https://www.aliexpress.com/item/Original-E-L-W6-4G-LTE-Mobile-Phone-4-5-854-480-MTK6735-Quad-core-1G...
And this is my APN settings to prove that I did it correctly according to the guide:
Any idea on why it's not working?
Thanks~
08-04-2018 10:32 PM
On my version of android, you should also make sure that all your apps have access to data. I did not have data before and almost all of my apps were set to wifi only. That was why I had data access but could not access the internet using chrome.
02-22-2018 04:47 PM
@RysovianGood to know. Androids are getting complicated these days!
02-22-2018 04:30 PM
It was really hidden
Settings>Data usage>Top Right Three Dot>Cellular networks>Telus>Celluar data>"switch on"
Thanks~!
02-22-2018 04:20 PM - edited 02-22-2018 04:22 PM
@Rysovianwrote:Still no luck with either... top right says it's connected, I think... since it shows 4G/3G; and even at almost full bar, it still gives the same error with both the web browser, but also won't connect on any other apps...
Is the data meter blocking things? If usage limit is set, make sure that the set limit is not exceeded. I also see gmail notification which suggests data is working and emails are synching. Could the problem be the browser is broken. How about trying a different browser.
02-22-2018 04:16 PM
02-22-2018 03:54 PM
@will13amwrote:
@Civic_Ewrote:
it should be isp.mb.com
you are putting sp.mb.com
hope it helps 🙂
It is supposed to be sp.mb.com. The isp.mb.com is supposed to be for the so called tethering APN. Both work. So just use sp.mb.com.
Interesting i checked my phone's setting and it said isp.mb.com...and data is working
02-22-2018 03:52 PM - edited 02-22-2018 04:19 PM
hope it helps 🙂
It is supposed to be sp.mb.com. The isp.mb.com is supposed to be for the so called tethering APN. Both work. So just use sp.mb.com. If you look carefully at the notification bar, there is a data connection. So, it doesn't seem to make sense the browser is not getting a data connection.
02-22-2018 03:32 PM
