06-19-2018 10:45 PM - edited 01-04-2022 06:13 PM
Hi, I just signed up for the $40/4GB promotion and wanted to check if the person signed me up correctly or if I need to change this. From the screenshot below the plan shows within the My Data & Add-Ons but does not show any of the other promotional items such as unlimited Talk Canada-wide, Unlimited International Text, etc. So not sure if this is just a data only plan or if they signed me up for the correct one.
06-20-2018 12:41 PM
Welcome to Public Mobile, @slowpoke! Enjoy. 🙂
06-20-2018 01:31 AM
Its the right plan. Have fun using it.
06-20-2018 12:12 AM
06-20-2018 12:06 AM
Thanks to both of you @kla168 and @Anonymous. I see the $40 per 30 days listed in "My Plan" now and within the Plan details.
06-19-2018 10:55 PM
@slowpoke You got a correct plan as it showed data 4GB at 3G speed
06-19-2018 10:51 PM - edited 06-20-2018 12:14 AM
Click on Plan Details under My Plan.
Edit: Although I'm having something a little similar. In Firefox on W10 I get a "Generic Error" when I click on Plan Details.
Try it in Edge and I see the short description of my plan and I can successfully click through to see the details. So the image above has some issues seemingly.
Edit again: More...if I click on Change Plan then I get nothing useful. Nothing under Current Plan. No list of options to change to. So too with Amount Due...blank.
hmm
It used to work. That's why I gave the instruction.
It all works fine in Edge. If I back off a bunch of add-ons in FF it still doesn't work.
Edit last: fixed. See below.
