Compatibility
Freight-train
Is the samsung Galaxy J260A compatible with the public mobile service?
Thanks
2 REPLIES 2
gblackma
@Freight-train were was this phone  used before? Can you provide us with a Klink to the phone? Thanks. These are PM frequencies. The minimum needed are these 3G Frequencies 850 MHz, Band 5 (UMTS/ HSPA).1900MHz, Band 2 (UMTS/ HSPA).
These ones are required for 4g LTE data
4G Frequencies 1700/ 2100 MHz AWS, Band 4 (LTE/ LTE Advanced).
                             700 MHz A/B/C/E, Band 12/13/17/29 (LTE/ LTE Advanced).
Stay safe.
dabr
Thanks
@Freight-train   You can try this link to search for compatibility.  Also make sure it's unlocked.
Edit: sorry wrong link.  you can try this link: http://willmyphonework.net/
