05-09-2020 11:55 AM - edited 01-05-2022 10:43 AM
I would like to know if the Samsung Galaxy A20S is compatible with this service?
05-09-2020 12:31 PM
For best results a phone needs to support B2 and B5 for 3G and bands B4 and B7 for LTE/4G.
05-09-2020 12:19 PM
@IsabDenm Yes, the phone is compatible with PM. My friend uses the phone with PM, and there was no issue. The database is a bit behind since Samsung A20 is still a quite new.
05-09-2020 12:14 PM
@IsabDenm Yes, this phone will work with this provider, don't worry and go for it! Welcome to PM.
05-09-2020 12:04 PM
@IsabDenm It will work, but isn't 4g LTE compatible. You will not get data on 4g LTE and no emergency alerts. You will only to get data in 3g. Welcome to PM. Stay safe. See link.
https://apn-canada.gishan.net/en/apn/public-mobile/samsung-galaxy-a20s
If you haven't already activated. Here's 4 articles on activation and porting and the Refer a friend reward if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
When entering your debit/ credit card information:
1. Enter the credit card address exactly as it appears on your statement ( capitalize all if necessary ).
2. Leave the apartment field blank, if applicable enter your apt in the street address field ie xxx - street address.
3. Enter your postal code without spaces ( if there is a space on the credit card statement then enter the first 5 digits only with the space).
05-09-2020 12:02 PM - edited 05-09-2020 12:10 PM
Your phone is compatible. Check the specific model.
Here are the specs:
https://www.gsmarena.com/samsung_galaxy_a20s-9852.php
| 3G bands | HSDPA 850 / 900 / 1900 / 2100 - SM-A207F/DS |
| HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100 - SM-A207M/DS | |
| 4G bands | 1, 2, 3, 5, 7, 8, 20, 28, 34, 38, 39, 40, 41 - SM-A207F/DS |
| 1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 20, 28, 38, 40, 41, 66 - SM-A207M/DS |
Public Mobile uses the following frequency bands:
Edit: does not have all the 4G bands. Does have the necessary 3G bands.
05-09-2020 11:58 AM
@IsabDenm I believe it is but you can go to this website and check if it is compatible on the telus network.
You will need your IME#
Get this by dialing *#06#
https://mobility.telus.com/en/ON/phones-and-devices/devicecompatibility.shtml
