07-02-2022
08:16 AM
07-02-2022
08:42 PM
computergeek541
I need a new phone.
I was looking at the Samsung a22, all I can find is the international model. Will that work on public mobile?
Thanks for the help!
07-02-2022 06:53 PM
Thank you for the input. I have yet to order a phone thankfully, still searching for one within my budget.
07-02-2022 08:59 AM - edited 07-02-2022 09:01 AM
I would avoid it if you have not make the order yet.
A22 is not a Canadian model. It will work but it wasn't designed specifically for Canada market
this are the frequencies the phone has and BOLD are the compatible ones
3G bands HSDPA 850 / 900 / 2100
4G bands 1, 3, 5, 7, 8, 20, 28, 38, 40, 41
and these are the bands used here:
Please note any phone should ideally have 3G B2, B5 and LTE B4 (or B66 instead of B4), B12 (or B17 instead of B12) for minimum coverage.
You phone will work, but won't work great. there could be some reception issue due to lack of compatible bands
If you can change your order for a phone more compatible with PM network, I would pick another one
But if you have the phone already, put a PM SIM there and test it out yourself.
07-02-2022 08:39 AM
@lbeancustomstry this link https://willmyphonework.net/
07-02-2022 08:33 AM
Public Mobile uses the following frequency bands:
