Community glitch. I have access to every solution marker.
Jessica_T
Um...? I can accept the solution but its not my topic. This is happening to every topic I go to. Even ones I didn't post in. @CS_Agent
I just tested, I went to another topic that I was never in, not mine, hit this is not the solution, it worked, then I went back and marked the same post as the solutiona and it worked. @ShawnC13 @will13am @Luddite @stonechucker @computergeek541 @mimmo @NDesai  Be on the look out, looks like anyone can get / change / remove solutions for anyone right now. Might want to lock this place down if its possible.
10 REPLIES 10
Hello - this defect should now be fixed. Apologies for the confusion this caused.
David_J
ute1978
@computergeek541 wrote:
@Alex888 wrote:
It just started happening with me too.
From what I know, this is a site-wide problem affecting all users.
Yes, can confirm as well.
Alex888
NDesai
@Jessica_T Thanks for reporting.
Let's have the team look into this. @Alan_K @David_J
mimmo
@David_J something to look into.@
Thanks @Jessica_T as we would have never noticed this.  Everyone , please use the honor system for now.  Most members are not supposed to be able to change solutions for every thead. I have contacted staff about this.
Jessica_T
@Murco wrote:
Its free solution day!
@MurcoYou can even go in and say "not the solution". Someone needs to lock this down if solutions are a part of rewards.
Murco
shartomjam
I just noticed that too.  It wasn't like that earlier today.
