11-30-2019 08:38 PM - edited 01-05-2022 08:14 AM
Hi,
I signed up for public mobile and community with the same email address however one I used a capital L and the other auto populated with a lower case L and I didn't notice it until now. Will this still link to my public mobile account if I earn any rewards or will the lower case/ upper case cause an issue?
Joining Public
12-01-2019 11:35 PM
Email addresses ARE NOT case sensitive. However, PM is using the email address not for emailing but to tie two things together and in my opinion they have it set to be exact, like a password. I didn't get my community cash reward automatically for 5 months but once it was finally sorted out I had changed several things so not sure what actually fixed it. One thing I found and fixed is exactly what @LDD @describes with one having an upper case letter that was lower case in the other place.
AE_Collector
12-01-2019 11:09 PM
@LDD I would message the mods as they can change or fix things for your community account and definitively answer the question if it makes a difference.
12-01-2019 11:01 PM
@geopublic wrote:@LDD No need to change anything because email addresses are not case sensitive.
I was told they were case-sensitive has something changed?
11-30-2019 09:36 PM
11-30-2019 09:21 PM
@LDD wrote:Doesn't seem to want to let me change to lowercase L in the community account. It's already in use by another account it says
That could be because it sees it as the same. Maybe try changing to another email you have and change it back.
11-30-2019 08:57 PM
@LDD well in that case I would message the moderator_team just to check in to it. Click on questions mark on the right hand side of the page and follow thru until you click submit ticket
11-30-2019 08:54 PM
11-30-2019 08:40 PM
@LDD i would change the community account email to the exact same one as your phone account
