Code
Buey
Why do I need verification code each time I log in?
@Yummy wrote:
Because you enabled 2FA verification.
Go to your account, Profile and tick off
@Yummy  FYI: 2FA was enabled by default on all accounts during the system upgrade.
JL9
I am with you, huge pain. I think the second time I signed in I deactivated it in the settings. I would recommend that to save a ton of time!
Logan2021
It's a security feature, although sometimes annoying, i do like to keep it active to ensure my account is secured. The above poster's mention how to deactivate it.
@Buey   this is a security settings called 2FA (two-form authentication), and is widely used these days for added protection
You can in fact disabled it if you decided to do so, just login to My Account, Profile page
Yummy
