Code refer to a friend
Lee80
Hi all, How can I find a code to refer to a friend to use Pulic Mobile? Thank you
7 REPLIES 7
dust2dust
Be very aware of things like ohs and zeros etc to make sure you're (the friend are) typing them in correctly.
Lee80
I got it, thank you so much
Lee80
I got it, thanks
dust2dust
Looking at a non-mobile browser scroll down. It's in a box that shifts for different images. Click the dots underneath to shift the image. It's called sharing is caring.
@Lee80
In the old and new website, go to Rewards section and login again. It will be located at the bottom of the page.
Lee80
Sorry, I did not see it. In the old version, I easily to see at the bottom corner, buy I did not see in the new version
dust2dust
Log in to your account and the code will be lower down in it's own little box area. It might be one of those shifting displays whatever those are called.
