05-12-2026
09:16 AM
06-08-2026
10:42 AM
Dunkman
Bought new phone and eSIM. Never got QR code and can’t activate my eSIM .
05-12-2026 09:48 AM
hi @Jojop
you can ask PM agent to check. Submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
05-12-2026 09:44 AM
Did all that ad still not installed
05-12-2026 09:20 AM
hi @Jojop
you don't need the QR code. You were supposed to use the PM app on the new phone to buy eSIM and the app will install the eSIM for you
check your new phone's SIM Manager or Settings, Cellular screen and see if the eSIM already installed there
if not, download the PM app on the new phone, login to the app, go to Account page and choose Buy sim card and select eSIM.
the system might still charge you the $5. Pay and install the esim first.
After the new esim is installed, submit a ticket with PM agent and for reimbursement. You can submit ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
