03-23-2023 01:12 PM
Hi, I was updating my profile, in address section why Delta Or Surrey not listed?
thanks
03-23-2023 01:15 PM
HI @Delta001 the city on the record is not critical, it is not used for credit card posting. So, you can just pick anyone close to you. Vancouver would be fine
03-23-2023 01:14 PM
@Delta001 , the pull down menu lists of cities is very incomplete. That data is not really used for much, so don't worry about not having your city in the list. Just select something close if you like.
03-23-2023 01:14 PM - edited 03-23-2023 01:14 PM
You will need to pick Vancouver if Surrey, Langley or Delta is not listed. They go by your postal code for locations.
PM only list the biggest cities.
