12-26-2022 11:01 AM
I am an existing customer. I did not receive my 2022 Christmas bonus. Please help
My Account
12-26-2022 11:58 AM
12-26-2022 11:12 AM
HI @Helen5 it is too late not to receive the Xmas bonus.
Just open ticket with PM CS agent and they will add it back for you quickly.
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
12-26-2022 11:04 AM - edited 12-26-2022 11:06 AM
All you should need to do is text YES2 to 4911
If that doesn’t work, contact support:
To reach a Customer Support Agent there are 2 methods:
- Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request). Click the result which states Click here to submit a ticket and follow the prompts, or,
- Send a private message to the Customer Support Agent by clicking here You’ll need to be logged into your Community account for the link to work.
