Checking voicemail on 50/50 and $15 plans from your own phone without using minutes.
02-27-2020 06:36 AM - edited 01-05-2022 11:00 AM
On the $10 50/50 plan and the 100 minute $15 plan it costs minutes to check your voicemail. I was fooling around on my F1 Android phone last night. And I found out that you could use either Google hangouts and Google dialer combined, or TextNow to check your PM voicemail over WiFi from your own phone without using minutes. Its pretty easy to do.
Simply dial your PM phone number from either app - dismiss the call when it rings (this sends the call to voicemail) - press the * key to enable you to enter your password. - enter it - and viola you are in your voicemail account - Hang up when finished. No minutes used.
I don't have access to an iPhone to test if their version of hangouts can do it. Can someone please test it and post if it's possible. Thanks.
Service
02-29-2020 07:52 AM - edited 02-29-2020 08:51 AM
Who are you to call my son a troll @will13am ? You are behaving like a spoiled child throwing a temper tantrum; Without apparently any parental supervision. Is someone paying you to behave in this way? If you had a problem with the post, why not put it in the lounge? That is within your purview. Maybe you should behave more like a William than a Willie.
@will13am wrote:I wish I could lock this thread. Please don't feed the troll any further.
02-27-2020 09:47 PM
@moalkhatib wrote:Checking voicemail is free, no minutes deducted
True when dialing from a line other than your mobile.
False when dialing from your mobile.
02-27-2020 09:19 PM
02-27-2020 03:22 PM - edited 03-09-2020 12:33 AM
Here is a current list of all voicemail access numbers across Canada that I know of I updated recently. You can dial your own number, or one of these numbers that are a local call from a land line (press * during greeting) to access your voicemail without consuming your outgoing mobile minutes.
You can also consider using a 3rd party voicemail service such as youmail. You manually reconfigure your 3 "conditional" call forwards to one of their canadian numbers instead of the default Public Mobile/Telus voicemail deposit number. Then your voicemails can be delivered to you by e-mail, so you don't have to dial anywhere at all to listen to the sound file attachment. 20 messages per month will additionally be transcribed to text for free. This way, I don't even have to install their APP. https://www.youmail.com/
02-27-2020 11:21 AM
I'm not sure what troll I should not be feeding.
02-27-2020 11:15 AM
02-27-2020 10:27 AM
While yes this is the same as using another phone to access voicemail...
another "trick" is to not use minutes for initial set up by going into the self-serve and resetting voicemail password which sets it to your 10 digit number and then using any exterior method as mentioned to set it up. ie. own-phone voip or a different phone.
Likely also mentioned in any number of past threads that will13am is suggesting.
02-27-2020 10:12 AM
Note that checking your voicemail consumes minutes only when you use your PM line to call.
It's free to check your voicemail from any other phone (including voip, landline, other cell phone, etc)
I haven't been on for a while, so I give you the benefit of the doubt.
02-27-2020 10:05 AM
Yes most of the services that offerr voicemail also offer the remote access retrieval, even the landlines.
02-27-2020 06:47 AM - edited 02-27-2020 07:32 AM
Bravo! Get an iPhone and make sure it works as well. Report back and I will give your another bravo post. Better yet use the search feature and find out how many times this has been covered in the community forum in the past and I will give you two bravo posts for every thread you are able to find. Let me help you, I found this one with 3 pages of discussion.
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/Voice-Mail-usage-minutes/td-p/350922
Honestly, you need to find a more useful pursuit in life. You can be helpful here, but only if there's somebody seeking help. There's no point in pretending to be helpful by flooding the community forum with these troll posts. The damage to your brand with this kind of nonsense far exceeds the value of your 30 bravo record.
![](/skins/images/97D9FB88C915001D8DAED89DBB2650DF/responsive_peak/images/icon_anonymous_message.png)
