Chatbot not working.
Blurst
I have tried to access the chatbot SIMon but no luck. I used 2 different browsers Safari & Firefox and the best I get is a blank page.
8 REPLIES 8
HI @Blurst   message is the way to go if Chatbot is not cooperating
Blurst
Tried private windows and clearing cache and cookies in both browsers. I give up wasted too much time on this.
HI@Blurst   did you try using Incognito mode?  Try it and see if it helps
@Blurst
i  tried now > Chatbot  is working,, use browser from computer,and clear cache and cookies and use one page inPrivate mode,
Blurst
Thanks I did that, but it still doesn't explain why the chatbot doesn't work.
RossN
@Blurst
hi if you need a cs agent and simon doesn't work for you
you can private message them here they can change your self serve account email
Blurst
I need to change my Email address.
dust2dust
What are you needing it for? Maybe we can help.
