Charged after porting out.
Epo
How do I get access to all my bills. I believe I should not have been charged.
@Epo wrote:
Support claims they charged me early so it was before the service was canceled. They said it works like Netflix, but with Netflix I could have used the service until my last paid subscription period was up, not been looked out instantly yet charged again.
The billing cycle can be confusing since it is every 30 days (not monthly).  Community members usually recommend porting out a few days before your payment date to avoid situations like yourself.
Epo
Meow
If you ported a day/two before renewal you might get charged and most likely PM prepared accounts for renewals.
slusagm
PM can help to issue refund
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:       https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox between 9AM-10PM EST (Mon-Sun), check here:    https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
@Epo  You need to engage support for refund if your owed $
send  a  private message   To CS_Agent
