Charged Twice for 3-month plan
08-17-2017 10:37 AM - edited 01-04-2022 02:30 PM
I recently ordered a 3-month 3G plan. After one day of use it was clear that the data internet would not work at all on my phone so I decided to change the plan to a 3-month 4G one. I assumed when I changed from one plan to the other that I would recieve a refund for the 3G plan but did not. Is this how the system is supposed to work?
Thanks.
08-17-2017 01:26 PM
Yes that is how the system is setup to work
When you change to a new plan it takes effect immediately and anything you had unused from your old subscription will be gone. Except for add-ons those will remain on your account until you use those up.
Private message the moderator team they are usually pretty good on fixing these issues and provide a credit
Good luck
08-17-2017 10:45 AM
afaik yes. try contacting the mods and ask for a refund, not sure if it`ll work out. Please include sim#, phone#, email used during activation, and detailed description of what happened.
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Moder...
http://productioncommunity.publicmobile.ca/t5/Getting-Started/Private-Messages-viewing-and-creating/...
