06-02-2020 12:45 PM - edited 01-05-2022 12:06 PM
06-02-2020 01:16 PM
If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
Two options are available: "Replace this credit card" and "Remove this credit card"
Use "Replace this credit card" to update the CC info
If you're having trouble registering or updating your credit card, here are a few tips you can try:
Hope this helps!
06-02-2020 12:50 PM - edited 06-02-2020 12:51 PM
As long as the credit card is American express, Visa or MasterCard issued by an American or Canadian bank it should work. Wait 50 minutes from last attempt, go to private/ incognito mode and try again to add it.
When entering your credit card information:
1. Enter the credit card address exactly as it appears on your statement ( capitalize all if necessary ).
2. Leave the apartment field blank, if applicable enter your apt in the street address field ie xxx - street address.
3. Enter your postal code without spaces ( if there is a space on the credit card statement then enter the first 5 digits only with the space).
If this doesn't work contact a moderator and explain your situation, ask them to add it for you.
There are 2 ways to contact the Moderator Team:
Keep an eye on the envelope top right of your screen. The mods answer will show up there. Stay safe.
Welcome to the community.
06-02-2020 12:49 PM
@jay15patel when you are putting in the be card info make sure everything matches for your address verbatim.
You can also try and use incognito mode or clear your browsing history and cache on your browser.
Let us know if it works out for you or not.
If you are still having issues you can contact the moderators here:
06-02-2020 12:49 PM
If you are using a payment card, leave the apartment/suite number in the payment information section blank.
06-02-2020 12:48 PM - edited 06-02-2020 12:49 PM
@jay15patel Follow the steps:
1. Enter the credit card address exactly as it appears on your statement (capitalize all if necessary).
2. Leave the apartment field blank. If needed, enter your apt in the street address field ie xxx - street address.
3. Enter your postal code without spaces (if there is a space on the credit card statement, then enter the first 5 digits only with the space).
@jay15patel wrote:I tried replacing the credit card info, but it doesn't register.
Log into My Account / Payment tab at top. Scroll down to Manage My Card.
