Changing subscription plan
dooba7
I am currently trying to change my subscription plan to this however it is not allowing me saying you are already subscribed to a plan.
I would appreciate any advice on how to fix this issue.
Thank you
marja29
Hi
yes  did this just a few days ago with no issues! Just log into your account. On subscription page change subscription to new plan you want then chose change on renewal day. A few days later my new subscription started with new plan and rate which was cheaper for me so good savings!
@dooba7
You will need to login to your account and go to Subscription and Add-on>Change Subscription>look for the plan and subscribe on your next renewal date.
HI @dooba7
yes, you did it on the wrong place if you have a PM account already
Please login to My Account, click Change Subscription and find this plan, and you can schedule a plan change using Change on Renewal
