03-05-2020 10:13 AM - edited 01-05-2022 09:47 AM
03-05-2020 10:37 AM
@Kris99 wrote:I recieved a 5Gb promotional data add on in November that I havent used all of yet. If I change my plan, will I lose my promotional add on?
Hey @Kris99,
On the Announcement post it says
"$35/mo or higher plan by December 2, 2019 11:59PM ET"
From my understanding as long as you choose a plan that is $35 or Higher you should be able to keep it.
However, If I were you before changing the plan It doesn't hurt to ask the Mod Team.
Send a Private Message to the Moderator Team.
Cheers!
03-05-2020 10:16 AM - edited 03-05-2020 10:19 AM
Most of the time, if you change plans, you will keep the promo add on.
You can try to find the terms and conditions of the specific promotion though.... You can try to check the old announcements section. (I quickly tried, but only can find a 3GB data promo)
Edit: (found the promo details)
