08-24-2017 02:18 PM - edited 01-04-2022 02:33 PM
Hello,
I got a sim card from my brother who was I Alberta and now I'm in Ontario. We changed all the details, email, address and etc to my details. I wanted to change the plan but it wouldn't let me. Is there a reason?
Also if the sim card was first under an address in Alberta and now in Ontraio will the unlimited call in the province will be working in Ontraio? Or should I just order a new sim card?
Thanks!
08-24-2017 03:44 PM
@tzliu wrote:In Long:
In Short:
You can make unlimited calls in Ontario. But without a long-distance add-on, you will not be able to receive any call from anywhere or make any call outside of Ontario.
I would check the Mod_team to see if they could "migrate" you from Alberta to Ontario. 🙂
Just to add a correction to this, this does not restrict you receiving calls from anywhere just making calls.
08-24-2017 03:40 PM
@noamsherf wrote:Hello,
Thanks!
Regarding the inability to do a plan change: Is the account in expired status? If so, plan changes on an expired account can only be done by a moderator. In that case,
click this Moderator_Team link to send a private message for assistance.
More info on moderators: http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
Include your account # and phone number and the details of the plan you want.
08-24-2017 03:20 PM - edited 08-24-2017 03:20 PM
If you change your number to, to a number available in the new province you are moving to. You will be able to make provincial calls in that province
Example. Im in Ontario, moving to BC. I change my number to a BC number. I can now make BC calls in my provincal calling. But i cannot call ontario numbers without the add on
08-24-2017 03:07 PM
In Long:
In Short:
