09-17-2021 06:57 PM - edited 01-06-2022 03:33 AM
Hi
I want to get a new number of my choice. When I try to change number, it does not give me the series of the number I want.
I know if I get a new SIM card, I can have the number I need. If I get a new SIM card and new number, will I be able to retain the balance of my existing account, like unused data, rewards etc etc.
Thanks
Maham
09-18-2021 08:40 AM
it is possible.. it's true it takes time.. but my "Perfect" textnow number I got was by keeep refreshing and changing to different cities. Just need patience. A perfect number is priceless
09-18-2021 08:33 AM - edited 09-18-2021 08:47 AM
@mahamimran wrote:
Actually the reason for doing this is to have same series of number for 3 of us sisters in the family. Just last digit would be different. My youngest sister got her number activated yesterday for the first time and me and my other sister thought, if we could all get the same series, that would be wonderful. That's the thought behind this.
That's practically impossible to achieve here.
The numbers are mostly given at random.
09-18-2021 07:54 AM
@mahamimran wrote:Ok, so I can't retain the old balance if I get a new SIM card and new number .... understood.
As far as only the new number on existing SIM card is concerned, it only shows 5 or 6 numbers to choose from ... does not give more option but if I get a new SIM card and new number, I can keep refreshing it till I find the number of my choice ... isn't it?
You can also try neighbouring towns/cities. This can provide numbers you may like as well.
09-17-2021 07:47 PM
you have to try it until you choice,
and Here How To Activate Online visit Here link for more information,
Activate your Public Mobile SIM card
You'll be up and running in just 4 easy steps, Here link
for new customers who activate online.only, To get 2GB of monthly bonus data for Free* when you activations on $35, $40, $50, $70 rate plans, for that Promo code for 2GB , 2GBBONUS , that monthly bonus for 2GB no expires but you have to keep your plan and if you changed your plan you will lost the promo 2GB,just to you know.
put it the email for it and the same email when you do a new activate, Here link,
so when Activate put it both code
1. Enter Promo Code for 2GB Free, ( 2GBBONUS )
2. Enter Friend Referral Code (??????) to you will receive a one-time credit of $10..,
they will applied within 72hr,,,
*information about Refer A Friend Reward, How Does It Work visit Here link,
plus Set up AutoPay and you will receive a $2 credit every 30 days. save money and safe and secure 100%.
Good Luck and your welcome to Public Mobile
with a Beautiful Service
you will be very happy
09-17-2021 07:16 PM
@mahamimran Understand.
just try to refresh, or keep back the page and go back, not the best way, but you get to keep your account balance and your rewards 🙂
09-17-2021 07:13 PM
09-17-2021 07:06 PM
@mahamimran wrote:Hi
Thanks
No, you won't be able to transfer account balance from one to another.
Also, not sure how you can get a new set of number if you activate new SIM , unless you know someone in the Mobile shop and knows the trick
usually, getting numbers from activation is the same as changing number via My Account. It will still give you 5 numbers to choose from. If you don't like it just refresh or keep changing city of your choice and hope the number comes up
09-17-2021 07:05 PM
@mahamimran : The change number let's you refresh for another set of numbers. It used to be that you could try for the last 4 digits during activation but not guaranteed. But that option is gone now.
No you can't transfer things from one account to another.
09-17-2021 07:03 PM - edited 09-17-2021 07:06 PM
you can Changing Your Number under existing account,
You can change your phone number up to 4 times every 30 days after you’ve activated. To change or transfer your number after activation, go to your Self Serve Account here link and:
No you can't be able to retain the balance of your existing account, like unused data, rewards etc. to New account with new SIM card is not allowed..then you have to start with brand a new Account with new SIM card,
