Changing my plan
kerago
Hey,
I signed up for the 6GB for 45$ plan a month ago while they had the "get your next 30 days for free" promo. Now I can see there was 45$ added to my account and I want to use them tewards my next month, but I didn't use much data so I was to get the 40/ 4.5 GB. Is it possible?
Thanx
11 REPLIES 11
kerago
Nope. Just kept trying and it finally worked
@kerago wrote:
Was able to make it now after 100 times trying.
Thank you all!
Anything in particular different that finally got it going?
kerago
Thank you all!
@kerago wrote:
tried it all, nothing helps. Any ideas?
How far do you get again? I can complete a future plan change.
How about a different computer? Operating system. Your phone.
kerago
@kerago wrote:
Every time I click on "change plan" I get this massage: "Oh no!
It looks like something went wrong, but don’t panic"
what to do?
Try another browser, clear cache/cookies, incognito mode
kerago
what to do?
@kerago wrote:
Thanks guys,
Can someone please guide me through this? from some reason I can't renew my plan
You're using some specific keywords.
For you you want to do a Change Plan. Then select a plan. Then select future at renewal time.
Renew means either renewal time or possibly now. I don't think you want now.
As popping said, you can select this promo plan now but it comes into force at your renewal.
Or just spend all your money and buy it now.
kerago
Thanks guys,
popping
@kerago
Yes, You can switch to a cheaper plan.  Today is the last day for the $40 4.5GB promo.  You need to to set it up tonight ASAP.  You can schedule to be changed at your next renewal date.
@kerago wrote:
Hey,
Thanx
Sure. Set up a future date plan change and it'll switch over on your renewal. No problem.
