09-04-2024
04:36 PM
09-04-2024
04:40 PM
computergeek541
The name that come up when I call someone isn’t my name and I want to get it changed to my name asap.
how can I do that?
09-04-2024 09:29 PM
PM does not send name to the receivers of your calls, they only send the number
The reason those who dont have your number see a different name is that their phone used some build in number-name lookup services. There are multiple ones depending on the devices those people have. For example, Samsung uses Hiya services. To update the name entry for you number on Hiya, you have to reach out to them directly here: https://hiyahelp.zendesk.com/hc/en-us/requests/new
09-04-2024 09:26 PM
That’s not my case. My question was how do I change the name that appears on my contact ID when I call someone that doesn’t have my number
09-04-2024 09:25 PM
How do I contact that third party company?
09-04-2024 09:24 PM
That’s not in my case. When I call someone that doesn’t have my number in their contacts a name shows that isn’t mine. My question is how do I change that name
09-04-2024 04:45 PM
@Olage1 , unless you block or spoof your number, the recipient's phone will receive the call based on your actual number and then associate it to the contact list on the phone. That should be what is displayed. For names not in the contact list, there should only be a phone number displayed, actual or spoofed.
09-04-2024 04:44 PM
You and your friends & family have to change it in your contact app.
09-04-2024 04:40 PM
@Olage1 wrote:The name that come up when I call someone isn’t my name and I want to get it changed to my name asap.
how can I do that?
This is not a Public Mobile issue. Public Mobile does not even send a name along with the phone number. Your phone number has been associated with someone else's name is a database that is being maintained by a thrid party. You'll need to contact that third party company.
09-04-2024 04:39 PM
@Olage1 You can’t PM doesn’t have caller ID only your phone number shows up ,unless the person you calling has you as a contact in there phone
