Change subscription failed
Harrylin2000629
Harrylin2000629
Thanks!
Harrylin2000629
Made the plan change using Private/Incognito/secret mode. It worked
Harrylin2000629
Thanks! I'll try it
hi @Harrylin2000629
you were using Change Now option?
payment can be tricky.  Try to make the plan change using Private/Incognito/secret mode on your browser
or if that also fails, ask support agent to help to make the change
please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
