03-10-2025
05:11 PM
03-16-2025
11:37 AM
Dunkman
i’m already a Public Mobile subscriber using an eSIM. How do I change to a physical SIM?
03-10-2025 10:18 PM
I have just done this, I suggest getting your physical SIM from Amazon, 1] it will be delivered faster, 2] it is half the price. When you get your physicial sim, just go to your PM app (account) and update the SIM # under your profile and insert the SIM to your phone and you are good to go.
03-10-2025 05:18 PM
Buy a physical PM sim from Telus or Koodo store or Amazon
Login My Account and go to Profile page and update sim card number there
