07-25-2020 06:52 AM - edited 01-05-2022 12:33 PM
Hello I just activated my Public Mobile number in Nova Scotia I have had an Ontario PC Mobile number for 10 years. I was told that I can switch back to my PC number once I activate new Public Mobile number. Can anyone help me do this?
08-04-2020 02:11 PM
Your PC ph# has to still be active to port. You need to contact a mod to do the port. If you port an out of province, people in the same area will be calling long distance to reach you.
08-03-2020 10:21 PM
@ETusesPublic wrote:I'm a new Public customer who was a longtime PC Mobile prepaid customer. I had a PC phone number.
On the original Public online activation form, it asked me to choose a new phone # and to later request a transfer of my old PC #. I didn't want to chance it. So I entered my PC phone # on the original Public online activation form. It was readily accepted. Not sure if it will work for everyone but it worked for me.
And can you receive calls and texts with the PM SIM in the phone? Porting during activation has been the way to do it for a little while now. Not sure why it gave you that message. I'd have to search a little to see if PC Mobile prepaid needed manual intervention too.
But if all incoming works for you then great...you're done.
08-03-2020 10:18 PM
07-25-2020 11:58 PM
@gpixel wrote:I have to say, the new and improved SIMon is a little bit better! 🤏
The "port request" entry has always went straight to the ticket submission process, at least ever since self serve stopped allowing porting requests.
07-25-2020 03:35 PM - edited 07-26-2020 02:41 AM
edit: @computergeek541 they changed the interface a little bit, and added some suggestions. or am I blind and that was always there lol
07-25-2020 02:47 PM - edited 07-25-2020 02:48 PM
@popping wrote:1. Tell SIMon what is the issue (important) - "Port Request"
2. Ask for "moderator"
3. SIMon will give your 2 choices. Click on the "Account-specific question"
4. Then, click on "No, I want a human"
5. Click "Submit a ticket"
6. Follow instruction to create support ticket.
7. After submitted a ticket, members should check their private message SENT folder for their ticket which they just created.
Steps 2 through 4 can be skipped. After typing in "port request", SIMon goes straight to ticket submission.
07-25-2020 01:48 PM
Welcome to PM. Enjoy your saving.
Create a moderator support ticket for help using this link https://publicmobile.ca.ada.support/chat/
If you cannot find your ticket in your SENT box, You did not create your support ticket yet. Also monitor your INBOX for any reply from moderator.
Click the envelop icon at the top right corner to access your private message mailbox.
You can also enable email notification after receiving a private message at your INBOX.
My settings --> PREFERENCES --> Private Messenger --> enable "Receive email notifications for new private messages' --> Save
07-25-2020 11:01 AM
@Emgloyn Don't be surprised if some locals mention that calling you is long distance for them.
Your HST charge will reflect Ontario not NS.
07-25-2020 11:00 AM
07-25-2020 07:03 AM - edited 07-25-2020 07:04 AM
You'll need to proceed to https://publicmobile.ca.ada.support/chat and once there, type "port request".
07-25-2020 07:02 AM
Follow number 2 since you activated your sim already.
Also if you used a referral code at signup for a $10 signup bonus. The credit will be applied within 72 hours of activating.
Welcome to Public Mobile 🙂
