10-19-2022 02:50 PM
I recently switched from the 3g plan to the $40.00 for 4.5 gb at 4G. I now see that the plans include 5gb at $40. Can I switch to that plan? An extra .5gb for the same price?
Thanks
10-19-2022 03:20 PM
I changed to the 4g a short time ago and recall the newer plan as being touted as the best deal at 4.5 gb/$41.25.
I checked my acct and it shows 4gb/$40
So I've changed plan for next cycle to 5gb/$40 and screen shot the details for future reference.
Thanks for all the replies
10-19-2022 03:12 PM
Thank you
10-19-2022 03:11 PM
@hTideGnow wrote:HI @SCH the $40 plan is always 5GB , I think. used to be 4.5GB + 0.5 GB for Autopay, but changed to just 5GB after they removed the requirement for Autopay discount
But., it is better to change to the current $40 plan as it is now 4G speed!!
The $40 3g plan has been modified before. It wasn't always 5GB. There was a time that it was 4.5GB (total) and another time when it was made worse to about 2.5GB (but that didn't last long).
10-19-2022 03:08 PM
@SCH wrote:I recently switched from the 3g plan to the $40.00 for 4.5 gb at 4G. I now see that the plans include 5gb at $40.
On second thought, please first go into your Self Serve account to check your plan details. There has been no recent $40 4g/4.5GB plan. You may already be on the plan that you want.
10-19-2022 03:05 PM
10-19-2022 03:01 PM
Yes of course. Set it up for your next renewal and it should change to it.
10-19-2022 03:01 PM - edited 10-19-2022 03:02 PM
@SCH wrote:I recently switched from the 3g plan to the $40.00 for 4.5 gb at 4G. I now see that the plans include 5gb at $40. Can I switch to that plan? An extra .5gb for the same price?
Yes, you can switch to it. To avoid losing the price paid for your current plan, you would need to pre-schedule the plan change to happen at the next renewal time.
